Author Topic: DPF Pressure Sensor  (Read 1585 times)
Offline AndyGB
DPF Pressure Sensor
« on: 11 July 2013, 02:54 »
Can someone give me a rough idea how much a DPF pressure sensor costs, and how long it would take to change?
Vehicle is a VW Golf MK5 GT 2.0 TDI 170.
Offline Rhyso
Re: DPF Pressure Sensor
« Reply #1 on: 11 July 2013, 22:34 »
£50-£60  :undecided:
Not sure on fitting but IT MUST BE CALIBRATED PROPERLY
I helped fix a car which had had the sensor replaced but not setup so the car was stuck in limp mode
Offline AndyGB
« Reply #2 on: 11 July 2013, 23:20 »
A new sensor cost me £51, which sounds about right then. However, the fitting was £66 which sounds expensive considering the simpleness of the part :(
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 13 July 2013, 21:59 »
its a 5 - 10 minute job £66 is a bit steep, unless that included some diagnostic fees.
