Author Topic: bagged a mk4 with agu  (Read 7886 times)
Offline barrym381
Re: bagged a mk4 with agu
« Reply #10 on: 11 July 2013, 12:13 »
Throw the engine in a 4mo shell :evil: ko4 etc all that then too :drool:
+1 on this idea  :smiley:
Offline sharki786
  • GOT BOOST??
« Reply #11 on: 11 July 2013, 12:42 »
3" downpipe will fit both ko3 and ko3s. As for your other mods it really depends on the kind of power you're aiming for.
Before you do anything make sure the engine is running well, as a minimum I'd do an oil/filter change and check for split boost pipes. When were the cambelt/waterpump last done? Waterpumps are renowned for failing. Oil pickup pipes also get blocked so is worth replacing if there is no record of it being done.
Once the car is running ok then look at mods, either forge d/v will be fine, TIP is a must, personally I'd get a full hose set as well, forge and ths intercoolers fit well, alternatively search for 'wellycooler' and take a look. I'd also think about air intake, again there's a comprehensive thread about if already if you search.
What power are you aiming for?
Thanks for that info dom. I will be changing cambelt waterpump and full service the car. What tip should i get?
im aiming for 300 horses. Thinking k03s hybrid??
Will be getting silicone hoses with a sprinter fmic.
I was reading about the s2000 filter (its on my watch list) lols
Thanks to other who are helpint me out with sound advise
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline dom
  • Back in a Mk4
« Reply #12 on: 11 July 2013, 13:01 »
I'd ditch the idea of a sprinter fmic, the cores are rubbish, especially if you're going for 300bhp. I'd also be looking at a Badger5 TIP, S2000 filter is a good setup but as far as I know it hasn't been tested on big power cars. I'd look into the R-tech induction kits that they sell.
If you're going for 300bhp it won't be cheap, you'll need fuel pump, injectors and a full exhaust/decat, you're also around the power/torque that will bend rods :wink:
Offline sharki786
  • GOT BOOST??
« Reply #13 on: 11 July 2013, 13:49 »
Whats the difference between the mofo (4mo) and the normal 1.8t shell?? Its confusing lols. Well the recovery guy should be on his way back now.
*****MK4 GTI T*****
Offline navmk4gti
« Reply #14 on: 11 July 2013, 14:14 »
Haldex system and i believe suspension etc all is different. Main reasom people do it is for the haldex system. So a 1.8t with  4wd :cool:
Offline barrym381
« Reply #15 on: 11 July 2013, 14:24 »
And 6speed box  :wink: but as Dom said its not cheap your looking at about 2k to do it right
« Last Edit: 11 July 2013, 14:28 by barrym381 »
Offline sharki786
  • GOT BOOST??
« Reply #16 on: 11 July 2013, 16:34 »
How does under 300horses sound? Lol. I will be replacing rods with IE rods but not just yet. Which fmic should i get? I will get a 3" straight through, deof wont be any probs if im running a k03?? How much is the badger5 tip? What about the forge tip? Seen on ebay for 75 which is better?
Which fuel pump will i need? Most likely il be putting engine in my mk3.
How much does r-tech sell his kits for?
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #17 on: 12 July 2013, 00:39 »
Well car arrived and im HAPPY :grin:
F all damage apart from the fool who repaired it without trying to push the dent out and decided to fill the fecker with more filler thats in my mates body shop lol. A good 5-9mm of filler was put in the car. Spray was good but was a shade off. Its a silver but with a blue tinge to it. Threw in £7 Vpowaaaaah as it was VERY low on pety. And im having a problem when i rev it to 3k rpm it hunts and will only settle when i tap the gas pedal. Its will hunt under its idle. Drivers seat heats up but passangers wont. Engine is VERY sweeeeeet nice and quiet only hear the injectors and the charcoal filter.
Anyway pics:
My bredwin filling her up with v juice  :cool:
The recaros:
Ma cazan checking out the damage (just needs a screw to hold the bumper back into place but might just buy a used bumper from classifieds):
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #18 on: 12 July 2013, 00:43 »
Oh yes. Another thing. When i drive the car to 3k revs and let go the dv will make a stuttering noise, is that right? I will try and get a vid of it tomoz :grin:
Love the way the recaros GRIP YA ARRSE TOIT :laugh:
*****MK4 GTI T*****
Offline barrym381
« Reply #19 on: 12 July 2013, 01:00 »
those seats are as rough as a witches tit  :laugh:
