Author Topic: Mk3 Engine Wiring Diagram  (Read 1388 times)
Offline Chazcad
« on: 10 July 2013, 21:32 »
Hi i am looking for a wiring diagram for a 93 e2 engine the car starts but cuts out after a minute have changed the ECU but fault still there any ideas.
Offline gazareth
Re: Mk3 Engine Wiring Diagram
« Reply #1 on: 11 July 2013, 21:46 »
I would check fuel pressure whilst running. and then check for spark after it cuts out for starters. could be bad coil/distributor/relay. you will have to give more detail of the symptoms? like:can it be revved/ is it misfiring/smelling of fuel/smoking/ rattling?
