I have an oil leak on my drivers side near the charge pipe.
It is not the charge pipe because I have just changed that to an agu one because I thought it was that.
But I think the oil was just leaking onto the charge pipe and then leaking off of the pancake pipe.
I have a oil patch about 2x50p every time I park up.
I have recently had the rocker gasket done, and it does appear to be weeping a little because it does feel oily at the front and back.
But would and oil leak from here cause that much oil? I have tried to look from the top and I can't see a very bad leak, I have also checked behind the cam belt cover and it looks ok.
I will jack it up tomorrow and have a better look at the back, but the oil is black on the floor.
