Author Topic: Cam shaft ID  (Read 1906 times)
Offline gizago
Cam shaft ID
« on: 07 July 2013, 22:59 »
Ive had a search and a google, but can't seem to find out what I need.
I have a cam that came with a car I bought, but the seller had no idea what it was, other than it was 'hot'.
There are no part numbers that give away what it might be, but I have measured it accross the base circle and from the heal to the nose.-
Any ideas what it might be??
Offline gazareth
Re: Cam shaft ID
« Reply #1 on: 08 July 2013, 23:13 »
hi its definatly not standard as the standard cam is about 10-10.5mm lift. that one you got there is 11.5 yeah?
Offline danny_p
Re: Cam shaft ID
« Reply #2 on: 09 July 2013, 20:22 »
268 degrees duration with 11.5 mm of lift would be a reasonable guess.
basicfast road cam,  nothing mental,  shoud idel like std  with a bit more kick up top
all the VW's have gone bar 1.
Offline gizago
Re: Cam shaft ID
« Reply #3 on: 10 July 2013, 14:34 »
Cheers guys- any idea what manufacturer or grind it might be? The box it came is unmarked so no help there. The guy I got the car from told me that the cam fitted was a fast road cam ( but gave no numbers) and that this one was even hotter than that, but from what you guys are saying this one might be fairly mild. What lift and duration is a stock cam?
Offline danny_p
Re: Cam shaft ID
« Reply #4 on: 10 July 2013, 22:08 »
unless there ae more marks cant really help you as to who made it.
they are usally stampd on the end
if it was stamped GS*H   it would be from kent cams.
BP***   it would likely be from piper
if it's not one of those it liley newman
Offline gizago
Re: Cam shaft ID
« Reply #5 on: 10 July 2013, 22:28 »
I can't see any more markings but ill double check. I'm used to aircooled stuff which is usually clearly stamped. Cheers for the help so far guys.
VW BUSH
Re: Cam shaft ID
« Reply #6 on: 10 July 2013, 22:59 »
Think danny is spot on
Offline gazareth
Re: Cam shaft ID
« Reply #7 on: 10 July 2013, 23:34 »
btw you never said what engine you have?
Offline gizago
Re: Cam shaft ID
« Reply #8 on: 11 July 2013, 09:01 »
Oh yeah!
8 valve digi.
Offline gizago
Re: Cam shaft ID
« Reply #9 on: 12 July 2013, 23:04 »
The only other marks are-
a G stamped on its own
the letters WZO
049G
and Germany.
I have no idea  :huh:
