Author Topic: 17" rims - what tyre size '97 GTI  (Read 5876 times)
Offline andy_k
« on: 06 July 2013, 22:28 »
stock tyre size is 205/50/R15
I've been offered some 17's with 215/45/17's
now, by my reckoning, that will be an inch or so larger in diameter which will put my speedo reading about 7% under
Does anybody run that set up or do I need to change the tyres to 40's or even 35's ?
Re: 17" rims - what tyre size '97 GTI
« Reply #1 on: 06 July 2013, 22:33 »
You will need 195 or 205/40/17, 215/45's will not fit they will rub and catch in lots of areas.
Offline andy_k
« Reply #2 on: 06 July 2013, 22:35 »
thanks - that dismisses those rims then :(
just out of interest what rubs?
car is stock ride height on standard springs/shocks
« Reply #3 on: 06 July 2013, 22:46 »
On stock height you might get away with it but they will catch the arches plus the speedo and gearing will be out.
Offline andy_k
« Reply #4 on: 06 July 2013, 23:10 »
cheers, I figured that the speedo and gearing would be out (I reckon about 7% reducing to approx 5% as tread wears down) but was worried about hitting springs more than arches.
I think I'll just pass on those rims and stick with the idea of running 16's as I don't want to be getting down to 35 profile tyres to keep the same diameter.
Thanks for your reply though :)
Offline gazareth
« Reply #5 on: 06 July 2013, 23:27 »
it all depends what you want to achieve. a car that handles great or a car that looks cool.
Offline andy_k
« Reply #6 on: 06 July 2013, 23:53 »
it's a case of looking for the ideal compromise :)
'great handling' isn't just down to wheels and tyres (as you know) and looking cool is always a bonus :)
I think that 16's are the way to go, I'll see what's available
Offline gazareth
« Reply #7 on: 07 July 2013, 13:31 »
ideally you want the lightest wheel you can get hold of to keep your unsprung weight down.
Offline Foreveryoungaus16v
« Reply #8 on: 07 July 2013, 14:17 »
I am running 205/40/17. Had them on when I got it. Looks wise its the nuts. However I am going to get 16's now as my speedo and gearing are out. Performance and handling are more important now. Plus 16's look really nice.
« Last Edit: 07 July 2013, 14:20 by Foreveryoungaus16v »
163 BHP (TSR POWER RUN)
Offline andy_k
« Reply #9 on: 07 July 2013, 14:26 »
A 205 40 17 should put your speedo and gearing out by about 2% on new tyres - by the time they have worn down a bit they should be very close to standard
The trouble is then that you start paying a price with low profile tyres making the suspension over harsh.
I agree with you, 16" seems to be a nice compromise
