Author Topic: Retrofitting an MFA  (Read 4673 times)
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: Retrofitting an MFA
« Reply #10 on: 07 July 2013, 16:41 »
Weil mines pretty accurate, ive done the maths. Outside temp is spot on when on the move as is oil temp. An important feature I would say.
On a racing car maybe....on an old mk3?...........
In this weather it quite important on a vr6 anyway.
Gavv8
« Reply #11 on: 07 July 2013, 16:58 »
Do you not think that the mighty Volkswagen may have designed the VR engine to cope with a hot british summers day?......just a thought..................failing that park it up and have an ice cream or something..... :wink: :smiley:
Offline FlashRedThree
  • MK III Flash Red 1.4 SE + MK V DBP 2.0T GTI
« Reply #12 on: 07 July 2013, 19:05 »
Look on  Google
Lol exactly. Dumb topic
Have you had a bad experience of this in the past or something? Quite weird how riled up this topic is making you.
I'm doing the same so will let you know how it goes. I'm gonna attempt air con too so will see how that one happens. :grin:
OK mate good luck lol.
I can see little or no point in fitting it on a 1.4 plus it is major work.
Just another thing that would've been nice to have really, but like you say after more research it seems a bit excessive so probably won't do it.
« Reply #13 on: 07 July 2013, 22:06 »
The early ones were poor cooling wise, so much so they had to run an extra electric water pump on the later cars.
Offline Gti_Jamo
« Reply #14 on: 08 July 2013, 00:40 »
Some maybe.....but my 200k lump needs constant monitoring. On old cars, as time goes on the cooling systems become less efficent. Oil that gets to hot looses its ability to lubricate properly. So you know, it is quite important. On a vr anyway.
Gavv8
« Reply #15 on: 08 July 2013, 22:33 »
Glad i've got an 8v..works fine in -10 degrees of snow and 30 degrees of sunshine.......no probs.
Offline Gti_Jamo
« Reply #16 on: 08 July 2013, 23:16 »
8v do generally run spot on oil temp wise. More air space under the bonnet. Less horses cramping the stable :wink:. Mine never moved from 90 but my early vr will run at 95 and today, with the hoachin day we had was at 102.
