Author Topic: LCR hub part number  (Read 871 times)
Offline vala
LCR hub part number
« on: 04 July 2013, 19:33 »
Anyone got the part numbers for the LCR hubs?
Thanks
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: LCR hub part number
« Reply #1 on: 06 July 2013, 11:25 »
I can get you the number for the TT hubs if that helps?
Offline vala
« Reply #2 on: 06 July 2013, 18:31 »
Wazzzer - I'm pretty sure I've read that although the hubs are the same amongst a number of cars in the VAG range the different manufacturers use a different part number. If I could get it off you anyhow, I'll see if my local TPS will be able to clarify what the LCR one is.
Thanks.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 06 July 2013, 22:38 »
Ok mate will grab it in the morning
