Author Topic: vacuum hose  (Read 1723 times)
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
vacuum hose
« on: 04 July 2013, 16:04 »
Am I ok to use 3mm silicone hose rather than the material covered type. Is there any difference?
Offline Thom89
  • Looking for an "Icebreaker"
Re: vacuum hose
« Reply #1 on: 04 July 2013, 18:07 »
As long as the hose doesn't collapse under vacuum, then not a problem, though the braided hose looks so much better, and is just as cheap to buy...
Thom
Offline Sgt_Lemon
  • 8v owners club
Re: vacuum hose
« Reply #2 on: 04 July 2013, 18:28 »
I got a 1m length of braided hose off fleabay for less than £3 delivered. Can't go wrong with that really.
Re: vacuum hose
« Reply #3 on: 04 July 2013, 20:16 »
Can't see any braided on fleabay just the silicone.
Offline Thom89
Re: vacuum hose
« Reply #4 on: 05 July 2013, 01:48 »
Most decent service garages should have a selection of different diameter hose on a dispenser, half a meter would be adequate to do all of the vac pipes, and generally the smaller diameter hose is braided, as it helps the hose to be bent, without crushing the cross section... this is important for proper operation of the vac systems
Thom
