Golf mk4
Wazzzer
clutch release bearing?
Topic: clutch release bearing? (Read 883 times)
rfn_hodgson
Here all the time
03 July 2013, 23:26 »
just wondering is this an easy/cheap fix??
clutch release bearing is a bit noisy when on idle with clutch released
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now
, ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers audi tt Quattro alloys
jamie16v
Guest
Re: clutch release bearing?
03 July 2013, 23:37 »
remove the dust cover for the bell housing and fill the bell housing with expanding foam..
that should quieten it down a bit!
in all seriousness, the only thing that`ll fix it is a new release bearing..
gazareth
03 July 2013, 23:44 »
gearbox needs taking out and full new clutch kit fitted. its not wise to change release bearing on its own. and the most important part is. do not buy a cheap clutch!
rfn_hodgson
Here all the time
04 July 2013, 00:11 »
cheers fellas
Golf mk4
Wazzzer
