Author Topic: please help!! 1.8t was dead is now ALIVE!!!  (Read 1677 times)
Offline ginga
« on: 03 July 2013, 10:37 »
Hi all
I'm puzzled and so is the mechanic. The car will not start, starter motor has been changed and so has the ignition switch. Turn the key and all the right noises are happening but turn it to start and nothing at all. Battery is fine fuel pump seem fine all the fuses are fine we have no idea why this f**k*r is not working. Please please help
« Last Edit: 03 July 2013, 14:22 by ginga »
Offline 52GTIPETE
Re: please help!! 1.8t dead
« Reply #1 on: 03 July 2013, 11:04 »
You checked the immobiliser is not malfunctioning?
Offline ginga
« Reply #2 on: 03 July 2013, 11:15 »
not massively sure how to check the immobiliser
Offline dom
  • Back in a Mk4
« Reply #3 on: 03 July 2013, 11:20 »
Sounds like an immobiliser issue to me as well :undecided:
Offline ginga
« Reply #4 on: 03 July 2013, 11:21 »
there are no unusual lights on. if it was an immobiliser problem would the engine still turn??
Offline ginga
« Reply #5 on: 03 July 2013, 11:22 »
forgot to say it has been scanned and was no codes or faults
Offline pickles
  • Next!!!
« Reply #6 on: 03 July 2013, 11:24 »
when you put your key in the ignition and give it a turn does theyellow immobiliser light , light up and go out .
see here for some info http://www.myturbodiesel.com/1000q/multi/immobilizer-VW-Audi-FAQ.htm
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline ginga
« Reply #7 on: 03 July 2013, 11:45 »
ok just went out again key in ignition the immobiliser light comes on and when you turn to start it the light goes off.
Offline pickles
  • Next!!!
« Reply #8 on: 03 July 2013, 12:17 »
hmmmm, might rule out the immobilizer then ?, is the new starter ok, can you hear or feel the solenoid moving when your trying to start it
« Last Edit: 03 July 2013, 12:19 by pickles »
Mapped
Nearly S3 time  :)
Offline ginga
« Reply #9 on: 03 July 2013, 12:23 »
yep starter motor is fine. the car bump starts fine too
