Author Topic: fuel pump?  (Read 1490 times)
Offline shelaghmk3gti
fuel pump?
« on: 02 July 2013, 12:38 »
Cars been giving me grief for a few days.. wanting to cut out when driving..mostly when slowing or taking a corner.. anyway finally gave up the ghost in a country lane last night (insert swear word here)
 Anyone know which fuse I need to check as I cant see a diagram clearly on my phone
 Mk3 8v gti
 And any other advice if course
Shelagh
Offline WadGTI
  • Golf GTI'er
Re: fuel pump?
« Reply #1 on: 02 July 2013, 13:04 »
when you swicth the ingintion on...do you hear the pump priming?
Offline Len
Re: fuel pump?
« Reply #2 on: 02 July 2013, 13:28 »
More likely some other cause.
There are many, many, many cutting out threads on here!
www.sas.org.uk
www.the-ace.org.uk
Offline lu3kyy22
Re: fuel pump?
« Reply #3 on: 02 July 2013, 18:36 »
I have been having the same problem with my 8v gti engine code AGG fuel pump wouldnt aswell prime after the car had been out for a run even if it was just a couple of minutes turn it off then go to straight it up no fuel pump the number on top if the fuel pump is 167 also look at ecu relay to which has 30 printed on the top i just give miy fusebox a wiggle and then the pump primes so changing fusebox lets hope it works......
hope this helps
Offline boneybradley
  • Back in a Mk3...
Re: fuel pump?
« Reply #4 on: 02 July 2013, 20:17 »
