Author Topic: Golf linkage heeeeeeelp!!!  (Read 2092 times)
Offline scoobwr1
« on: 01 July 2013, 23:50 »
Hi guys, just bought my first Mk2 gti , its had a vr6 conversion.
Im having issues with the gears, first seems to be up near reverse, as in you have to push the gear lever down to get up into first, now this clearly aint normal as you should only need to push the lever down for reverse so what is the issue??
thanks
Offline gazareth
Re: Golf linkage heeeeeeelp!!!
« Reply #1 on: 02 July 2013, 00:31 »
hi first I would check the gearshift mechanism on top of the gearbox to see if anything is loose or excessively worn. have you much free play at gearstick?
Offline scoobwr1
« Reply #2 on: 02 July 2013, 02:34 »
Not a huge amount of free play, a bit yeah
Offline gazareth
« Reply #3 on: 02 July 2013, 21:46 »
does it go through all the other gears fine?
Offline Mr Blue
« Reply #4 on: 02 July 2013, 21:55 »
What gearbox? Cable change?
Offline gazareth
« Reply #5 on: 02 July 2013, 23:27 »
is there not a d shaped locator hole on 1 of the gear shifts on top of box that comes loose and wears???
Offline scoobwr1
« Reply #6 on: 30 July 2013, 17:33 »
to be honest guys on the tower ontop of the box it does seem to be pretty vague & alot of play there,
Offline typhtoeknee
« Reply #7 on: 31 July 2013, 23:42 »
Strangely mine has exactly the same issue, first is a lottery at junctions and the easiest way is to slightly depress like I am aiming for reverse and slot it in. Someone sugguested play and a housing allignment not driven this week but last time wasn't too bad. My mind now thinks if it went in gear smoothly you're probably in 3rd  :grin: The other gears work like a treat, it did have a gear linkage kit on it weight etc maybe the previous owner messed it up slightly.
Saying that if you have VR6 then is it not a cable gearbox mines is boggo 91 8V
Offline gazareth
« Reply #8 on: 01 August 2013, 00:50 »
I wouldn't start adjusting the cables until you sort out any wear in the linkage.get rid of the play and you may find there is no adjustment needed.
