Golf mk4
Wazzzer
Knocking when turning.?
Topic: Knocking when turning.? (Read 1534 times)
ryanbrook
GTI forum regular
01 July 2013, 23:09 »
When I make a tight turn slowly I get knock knock knock sound. Also getting a knock when I hit a pot hole..??
Ryan
jamie16v
Guest
Re: Knocking when turning.?
01 July 2013, 23:10 »
cv joint, which direction do you turn when it happens?.
ryanbrook
GTI forum regular
01 July 2013, 23:18 »
both, mainly right though, would a cv cause knocking though?
jamie16v
Guest
01 July 2013, 23:21 »
a worn cv joint can normally sound like a train on a track - clickety clack - train on a track - clickety clack train on a track - clickety clack - train on a track - clickety clack train on a track - clickety clack - train on a track - clickety clack train on a track - clickety clack - train on a track - clickety clack
gazareth
01 July 2013, 23:32 »
yeah could be a cv. have a look at your cv boots to see if any are split. they rarely fail unless they lose their grease.
ryanbrook
GTI forum regular
02 July 2013, 00:07 »
previously checked this and the cv boot was fine, anyhow i took it off and chucked some more grease in there anyway. still knocking though
ryanbrook
GTI forum regular
Reply #6 on:
02 July 2013, 00:10 »
Also when turning sometimes it doesn't make a sound, then couple days later it will knock.
gazareth
Reply #7 on:
02 July 2013, 00:39 »
if its knocking while your turning the steering it could be a partially seized strut top bearing.
navmk4gti
Forum addict
Reply #8 on:
02 July 2013, 01:22 »
Can be wheel bearing when you turn puts load that side car. Does it happen both way you turn?
Website:
https://www.theonestopledshop.com/
Steve_PD
Serious forum addict
Cruising around in a Land Cruiser
Reply #9 on:
02 July 2013, 03:01 »
Jack the car up and grab hold of the driveshaft and try to rotate it, there should be minimal amount of play in it.
Golf mk4
Wazzzer
