Golf mk4
Wazzzer
Mk4 20V turbo running hot
Topic: Mk4 20V turbo running hot (Read 1922 times)
Kelvin1977
30 June 2013, 20:08 »
Ok wonder if you lot can help I have a 2002 20V Turbo and I am getting some strange things happening. 95% of the time goes up too 90 deg and sits perfect, but every so often it rises to 100/110 but no higher. Then drops back to 90? I would have guessed at water pump but it was done less than 5k ago with the cambelt and also thermostat and housing. Could it be a temp sensor or dodgy fan switch
jamie16v
Guest
Re: Mk4 20V turbo running hot
30 June 2013, 20:16 »
any particular pattern to this happening?. sitting in traffic, on the move etc?.
Kelvin1977
30 June 2013, 20:21 »
No completely random only thing I think is does it after its been at tick over for 5 mins but does not rise when I am sitting but about 10 mins after I have got going again.
jamie16v
Guest
30 June 2013, 21:33 »
leave it run on idle for a while and monitor it, see if the fan kicks in etc.. scan for codes too, it might show up a code for the coolant temp sensor, implausible signal?.
navmk4gti
Forum addict
30 June 2013, 21:41 »
Temp sensor my vote
Website:
https://www.theonestopledshop.com/
Kelvin1977
30 June 2013, 22:05 »
Done that mate goes up too 90 and holds other times goes up to either 100 or 110 but never any higher. Have scanned no codes
gazareth
Reply #6 on:
01 July 2013, 00:00 »
the fan usually comes on just over 100c. rev it to 3000rpm in neutral until gauge goes right up then just before it hits the red zone it should fall back down. then you know your fan is coming on.
Kelvin1977
Reply #7 on:
01 July 2013, 21:16 »
Ok will try put fan is working as have heard it when I get out of car
gazareth
Reply #8 on:
01 July 2013, 22:41 »
are you getting hot air through the heater blower?
Kelvin1977
Reply #9 on:
02 July 2013, 20:30 »
Yes mate no probs there and no other probs
Golf mk4
Wazzzer
