Author Topic: Tdi with serious smoking issues!  (Read 2888 times)
Offline daveob1g60
« on: 29 June 2013, 23:47 »
hi guys,
Sorry tried to put this in the tdi section but it won't let me post there?
i've just bought a 2002 TDI 130 with 110k on the clock.
it hass the dreded loud boost noise when accelerating which i put down to a hole in one of the pipes.
i also noticed clouds of smoke coming into the car through the boot area (which i can't currently open due to the solenoid not working ) this has discolored the roof lining and comes off when you rub it so it definitely soot
when we checked the top hose it looked a little perished but no hole but i replaced it anyway as a precaution.
the problem is still there.
looking at the inter cooler there is a large amount of oil / gunk all around the inter cooler and pipes.
So today we connected a smoke machine to the air intake and blew smoke through it to identify any further leaks and it came poring out of the intercooler, suggesting a hole and a new intercooler!
what would you recommend as a replacement?
in two minds as to just replace the intercooler alone with something like this:-
http://www.fastrads.co.uk/intercoolers/volkswagen/golf/1-9tdi-mk4/index.html
 or go the whole hog and get the full darkside kit that replaces the pipe work as well??:-
http://www.darksidedevelopments.co.uk/products/upgraded-side-mount-intercooler-kit-for-1-9-tdi-pd130-asz-engine.html
reading all the posts on here it seems boost leaks are quite a common problem so tempted to replace everything so all the pipework is metal and shouldn't leak?
also bought an egr delete pipe from allard which i'm going to return as i don't want to cut the new pipe i've bought but i'm going to order the darkside one that fits to the standard pipe with no cutting.
if i go the dark side route and replace the lot will the solve all the problems or do you think i may still need a turbo etc??
been told the soot is due to the inter cooler creating the extra smoke and due to the exhaust not clearing the rear bumper in comes up through the ventilation holes in the boot?
had it on vagcom as well and didn't throw any codes out
sorry for such a long first post but wanted to give as much info as possible
any help / advice would be very much appriciated and look forward to attending some track / show days once it's all done!
thanks again - dave
Offline dom
  • Back in a Mk4
Re: Tdi with serious smoking issues!
« Reply #1 on: 30 June 2013, 09:36 »
I don't know much about diesels, but I do know the guys at darkside (they are making me a custom intercooler for mine). Their work is second to none when it comes to diesels and I wouldn't hesitate to buy their kit :afro:
Offline EsSeX dAn
« Reply #2 on: 30 June 2013, 11:02 »
personally id rather spend the extra and fit the darkside kit. looks quite good! the other good thing with this is youll loose those silly bayonet clip in joints which are prone to leaking. once this is done your excess smoking problem should clear. itll still smoke (they all do) but not as much
the excess soot is there as because of the intercooler is basically overfielling for the air thats going in. but once the cooler is fixed the right amount of air will go in for the fuel and have a cleaner burn.
as for the smoke in the boot thing, id take a look and block up the holes. sounds a but wierd to me! lol
i think i love you.....
Offline daveob1g60
« Reply #3 on: 30 June 2013, 21:39 »
Cheers for the replies guys!
That was my thinking as well, going to order the kit up and get the egr at the same time so hopefully back on track then.  :smiley:
Tried to get in the boot over the weekend but the solinoid has never worked and the key doesn't turn in the boot. Did see a you tube vid on how to get it open but was American and seems different?
Any tips to get in there?
I can see the lock mechanism but can't work out how to pop it?
Thanks again!
Offline EsSeX dAn
« Reply #4 on: 01 July 2013, 01:11 »
squirt a bit of wd40 in the lock barrell, then wiggle the key in. once its in wiggle it in nd out a few times to loosen is up then u should be able to undo it.
failing that jack the back up and look for any obvious holes or anthing like that
as for undoing the lock from inside i cant help you i just used wd40 trick on mine and it was ok!
