Author Topic: Ride height advice please...  (Read 4094 times)
Offline Waspy
« on: 29 June 2013, 21:48 »
So my car is currently on coilovers, as it was when I bought it, but I have no idea what height it is set at. I am pretty certain the driver side coilover is knackered (there is next to no bounce back if a bounce on it, there is on the others). When I am driving I have some issues. On the likes of B roads, I get quite a bit of scraping on the tires, no constant, but over every tiny bounce. On regular roads I get scraping on hard lefts. The scraping is only on drive side. I wouldn't care, but it is causing damage to the tire. So that is the back story, now for my thinking.
THE WHEELS: I have 15" Borbets with a 7" width. I can't make out the offsets on them, but I calculated it to be ET25. This calculator (http://www.1010tires.com/Tools/Wheel-Offset-Calculator) shows that means I have 16mm less outside clearance than a standard set of BBS. Probably won't help.
THE SUSPENSION: As mentioned I think it is partially f**ked. But also too low, I know it isn't as low as some of you guys have set up, but it is a daily car, and tires are expensive... So, I plan on fitting springs and shocks. With a 30mm drop. Question is, will this actually give me any more clearance? Would love you guys thoughts on what ride heights combine drivability without looking too high.
I know this is a wall of text, but I really appreciate the help before I shell out on new suspension.
These are some pics of the car, and wheel in question:
Offline Sgt_Lemon
  • 8v owners club
Re: Ride height advice please...
« Reply #1 on: 29 June 2013, 21:51 »
Are the coilovers not adjustable? Can you not raise the car up 1/2" and see how it is around the block?
Offline Waspy
« Reply #2 on: 29 June 2013, 21:54 »
I was going to, about an hour ago I raised the driver side 10mm, but it genuinely didn't change the clearance... Which was odd, I don't know if its just because that one is knackered?
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 29 June 2013, 21:55 »
Clearance looks ok to me... Are the shocks/springs knackered?
Or is it rubbing on full lock?
I would go for stock suspension with Eibach -40mm (what I have fitted) and have no issue's... If fitting coilovers ONLY fit good quality ones  - not Jom's etc...
For More Info Click To See;
Offline Waspy
« Reply #4 on: 29 June 2013, 22:00 »
It's what I am thinking.
It doesn't rub on full lock, so I thought it was fine, but when driving it rubs on hard lefts and bouncy roads
Won't be fitting coilovers. My plan was stock shocks with -30mm Eibachs, so it is great to know it works for you, cheers
Oh, and what width are your wheel, out of interest?
Offline gazareth
« Reply #5 on: 29 June 2013, 23:47 »
has your car got the wide track set up of the mk3 golf? there is quite a few options for you. you could stick on some wheels with less offset. you could raise suspension up a touch or just make it so its rock solid. or if its only catching slightly you could roll the arch and cut back the plastic arch trim. tbh I think a 35mm drop is a good compromise for a daily runner.
Offline Waspy
« Reply #6 on: 30 June 2013, 00:42 »
I dont really fancy rolling the arches, new wheels is an option, but I am going to get new suspension anyway as the current coilovers are horrible. I was just wondering what height would be safe with my current wheels.
Another thought, new tires with a lower wall should help too, shouldn't it?
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #7 on: 30 June 2013, 01:07 »
Wide track would be 5 stud..
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #8 on: 30 June 2013, 01:10 »
Don't roll the arches as you are just opening another can of worms... try stock shocks and eibach springs -40mm not 60mm and stick with 15" rims with 185/195 50/55 tread and all should be fine.
I have a feeling that you coilovers are shagged...
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #9 on: 30 June 2013, 01:12 »
Width of wheels don't mean anything if its compensated by the offset!
