Author Topic: mk2 golf gti 8v anti roll bar upgrade?  (Read 6539 times)
Offline gazareth
« on: 28 June 2013, 21:38 »
hey guys does anyone know if there is a stronger arb I could fit to front of my mk2 gti? I was thinking maybe a mk3 16v gti one with a bit of modding??? anyone know the diameter of mk3 one? cheers
Offline X4MGS
  • VAG Parts SNOB!!!
Re: mk2 golf gti 8v anti roll bar upgrade?
« Reply #1 on: 28 June 2013, 21:53 »
Eibach do them - I have them fitted to mine...
For More Info Click To See;
Offline gazareth
« Reply #2 on: 28 June 2013, 23:22 »
yeah I wouldn't mind a set of them but im kinda on a budget at the moment so was just after a cheap easy upgrade. I know the mk3 one will fit the subframe mounts but has a different fitting at wishbone. was thinking maybe cut it down to fit or make up some brackets for it. or a bit of both. do the eibach make a big difference?
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 28 June 2013, 23:51 »
Yeah makes it nice and tight at the front and rear...
Offline gazareth
« Reply #4 on: 29 June 2013, 12:44 »
aso do you know if any mk3 ones will fit? or seat maybe? I was also thinking maybe I could hang a smaller bar at front of wishbones as there seems to be plenty room there. a bit overkill I know. but I just love to give myself problems.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #5 on: 29 June 2013, 12:54 »
I think a MK3 has different fittings on the ends. Sure I read it somewhere.
Offline gazareth
« Reply #6 on: 29 June 2013, 13:02 »
yeah it does. if I remember right the end links bolt to side of wishbone and bar is longer to compensate for the wider track. but if the bar was the same shape up to a point then the ends could be trimmed down to fit mk2 golf wishbones. surely over 23years and with them rusting aswell the arbs would weaken a bit. maybe a brand new standard one would make a big difference. prob cost a fortune though.
Offline Simeon
« Reply #7 on: 03 July 2013, 13:34 »
You can't use a mk3 one. You can get a set of Eibachs for under 200quid second hand if you keep an eye out .. if you're on that much of a budget then I really wouldn't bother.
A cheaper option (but harder to find) would be a G60 one as these are a couple of mm thicker, there was one on ebay for 50quid for ages but don't know if it has sold now.
Offline gazareth
« Reply #8 on: 03 July 2013, 21:05 »
im not on a budget as such. just like to be wise with my pennies with the way things are these days. them eibach anti roll bars are just way to overpriced. anyway back to the g60 anti roll bar. will you take 40 quid for it?
Offline Simeon
« Reply #9 on: 06 July 2013, 00:59 »
It wasn't mine mate, I just saw it on ebay a little while ago. Eibachs are worth the money, make a huge improvement :)
