Author Topic: project mk2 410  (Read 56475 times)
Offline gazareth
Re: project mk2 410
« Reply #60 on: 30 June 2013, 02:56 »
that looks like a water temp gauge on the left but its the same thing really. put up a pic of the back of the gauges if you can and we tell you how it wires in.
Offline X4MGS
  • VAG Parts SNOB!!!
Re: project mk2 410
« Reply #61 on: 30 June 2013, 03:19 »
Oil pressure senders can go for stupid money at times... Circa £50.00  :(
For More Info Click To See;
Offline X4MGS
  • VAG Parts SNOB!!!
Re: project mk2 410
« Reply #62 on: 30 June 2013, 03:21 »
Both take the temp's from the same place ... So won't make any difference...
Offline gazareth
Re: project mk2 410
« Reply #63 on: 30 June 2013, 03:36 »
how do you mean they take the temps from the same place?
Offline X4MGS
  • VAG Parts SNOB!!!
Re: project mk2 410
« Reply #64 on: 30 June 2013, 03:41 »
Why do you need the T piece????
To put 2 temp sender's in!!
Offline Sgt_Lemon
  • 8v owners club
Re: project mk2 410
« Reply #65 on: 30 June 2013, 08:36 »
One sends the signal to the mfa and the other to the gauges. Without the t piece you can only chose one
Offline gazareth
Re: project mk2 410
« Reply #66 on: 30 June 2013, 16:41 »
ah I thought you meant the water temp and the oil temp came of the same point on the engine lol. I wouldn't bother with the mfa oil temp. just hook the vdo 1 up and since its right there in front of you that's the 1 you will be using most.
Offline VWchapman17
Re: project mk2 410
« Reply #67 on: 30 June 2013, 21:15 »
do i really have to spend like 20 quid on a oil temp sender..
Offline VWchapman17
Re: project mk2 410
« Reply #69 on: 30 June 2013, 21:20 »
is there no other cheaper sensor that will fit, ive seen water/oil temp sensors for a tenner buy now..
