Author Topic: body shop messed up my new rear window decal - what d'you think?  (Read 5242 times)
Offline MrWolf
Hi guys, I just got my Mark 2 back after having some body work done, which necessitated losing the original decal round the rear window. Garage couldn't get a decal but I sourced a repro one no problem. Not sure how to put images in, so I'll describe what happened.
When I picked up the car yesterday, I could see there were air bubbles under the decal but decided not to make a fuss there and then. But on checking the car properly at home, I found there's almost no part of the decal free of air bubbles which range from 1/4" to over an inch in length. Think of someone covered in a bad, blistering allergic rash and that's what my decal looks like.
Also, the old decal covered all the paintwork around and below the rear window, up to the angle where the metalwork drops away to form the side or the rear. You know what I mean? To be honest, on a metallic grey car I never even noticed the decal before.
But now the decal stops in a wavy, diagonal line about 1/2" above the edge of that bit of the tailgate. It fits better on one side than the other.
It's a real mess. What would you do at this point?
I talked to another body shop for advice, and they said decal work really needs to be done by a specialist, but they couldn't recommend one as they didn't seem to know a local one they were happy with. Is this right? And does anybody know a specialist in the Dorset/Hampshire/Wiltshire area that they'd recommend?
Then I called the guy who did the work and told him about the air bubbles. He said, "It wasn't like that when it left here," but it was and anyway, what could I have done to make them appear? He then said it was almost perfect when he applied it, and the air bubbles must've appeared because he left my car in the sun. He said they'd probably disappear, but couldn't tell me when, then said 2-3 weeks, then said they might not. He blamed the solvents in paint and said it was always a problem putting decals on fresh paint. I asked if it would've worked better on older paint and he said yes - but he didn't tell me that before he did the work!
I asked about removing the decal and he made it sound like I could just take it off if I wanted to, as though I could easily peel it off if I warmed it with a hairdrier. I asked him if he'd do it for me and all of a sudden it was difficult: he'd have to take the rear window out, etc - so how I was supposed to do it was a mystery. And he said the paintwork would look bad underneath.
We've left it that I'm going to take the car back in tomorrow just for him to look at.
What d'you reckon my best options are?
Offline X4MGS
  • VAG Parts SNOB!!!
Send Thom a message and ask him, he's a painter by trade!!
I had mine done at a body shop and they got a sign writer to apply it so they didn't have this issue.
As for actual size -sorry but thats what you get with using non genuine items....
For More Info Click To See;
Offline oakgreener
I seem to recall someone, some time ago, having it sprayed on in matt. Someone may info on this remedy
Offline Mr Blue
DONT spray it. Looks terrible.
http://www.volkswagenstickers.co.uk/ supply the decals and they are the same size and finish as the genuine ones.
Not a specialist job. Just a window out job, some washing liquid and a credit card to get the bubbles out.
I was going to mention solvents in the paint but I'm no painter. I had a few bubbles and just used a pin to pop them.
« Last Edit: 27 June 2013, 18:36 by Mr Blue »
Offline Thom89
  • Looking for an "Icebreaker"
I'd get the decal off asap, before it has a chance to affect the paint!
DO NOT use a hair dryer to remove the decal, this will just soften the fresh paint, and run a much higher risk of pulling the paint off!  Your painter will know this, hence his reluctance to remove it!
Thom
Offline MrWolf
Thanks for all the replies and ideas.
Offline MrWolf
... how DO you put an image in? I hit the image button and put a URL in between, but nothing showed up. You may never see the horror that is my blistered decal.
Anyway, to respond properly...
MrBlue, that's where I got the decal from, so I don't think the problem lies with the decal. Dan was very helpful throughout.
D'you think popping the bubbles (on one that's done properly, that is) would lead to any problems? My Mark 2 had a circle of rust underneath the decal when I bought it, and that's what I got fixed - or tried to. There was a tiny hole in the decal at the centre of the rust circle, and I always wondered if water got in and couldn't escape. I guess as long as you don't stab the paintwork you're OK.
Thom, how d'you get the decal off without warming it up? And do you have to take the rear window out to get the decal off/on?
I'm thinking maybe I should get the decal taken off and the paint fixed and just leave it. Looking on the internet today, some people seem to have got rid of it anyway. I only wanted it put back on because my VW engineer said it was a sign of a Golf being a GTi. I didn't want it to be the only GTi without one, but now I wish I hadn't bothered.
Thanks, guys.
Offline t-dub1902
Even if it is fresh paint if its been prepped correctly surely a sticker wont pull the paint off?!
Ive stuck gaffa tape to fresh paint to check prep and yes if preps no good it will come off haha
But if done correctly if shouldent come off :/
Maybe they was rushing and put the sticker on when the paint wasent fully cured?
Offline t-dub1902
Oh and as for rust anything that traps dirt and water creates rust, trims, stickers will all start over time
Offline MrWolf
See the first 3 pix here:
http://www.flickr.com/photos/danny_girl/with/304311090/
(But feel free to browse the rest if you're a fan of 'Where Eagles Dare'!)
Just looked in the garage - nope, the air bubbles haven't gone yet...  :cry:
