Author Topic: Mk4 agu not starting  (Read 1767 times)
Offline luke
  • When in doubt, whip it out!
« on: 26 June 2013, 23:49 »
Car started when I finished work but cut out a few seconds after, tried bump starting it but no avail, then tried with battery booster which didn't start first time but after a minute did, ran fine and changed the battery then tonight, driving home it started spluttering and juddering, then cut out again, any ideas?
1985 mk2 gti type 19 8v
2018 t roc sel 1.6tdi
Offline navmk4gti
Re: Mk4 agu not starting
« Reply #1 on: 27 June 2013, 00:12 »
Have you scanned it? May be your ingnition amp which is on the air box
Offline luke
« Reply #2 on: 27 June 2013, 00:15 »
Haven't yet, was thinking of buying one this weekend too, I first thought it could be maf related as it ran rough before and the maf was loose, it has an aftermarket cone filter so checked all surrounding plugs
Offline navmk4gti
« Reply #3 on: 27 June 2013, 00:29 »
Unplug the maf then see how it is ...not heard of maf stopping it starting tho.. may be the reason it runs ruff
Offline luke
« Reply #4 on: 27 June 2013, 00:31 »
Going to take the old battery tomorrow and fit it and see if that will make it start to nurse it home
Offline cullygti
« Reply #5 on: 27 June 2013, 00:33 »
Maybe a failing crank sensor like mine buddy  :wink:
Offline luke
« Reply #6 on: 27 June 2013, 00:34 »
Looks like my bonus isn't being spent on my holiday to lanzarote and more spending on this little fecker, not treating it to coilovers now  :grin:
Offline luke
« Reply #7 on: 27 June 2013, 07:28 »
Been back to the car this morning, didn't start, took the fuel return and fuel pipe off and tried to start which it did for half a second then cut out, then put the pipes back on and started up and nursed if home
Offline luke
« Reply #8 on: 29 June 2013, 12:57 »
Can't hear the fuel pump priming, will be going to the local vw breakers later to pick up a cupra r fuel pump and going to see if they have any crank sensors in stock, fit them both and see if problem persists
jamie16v
« Reply #9 on: 29 June 2013, 14:25 »
fuel pump relay perhaps?
