Author Topic: Catch can and pcv system  (Read 2217 times)
Offline Jayz
« on: 26 June 2013, 19:57 »
Hi peeps i have a 2001 y reg 1.8t aum and im looking to put in a catch can in over the weekend, other than that what do i need e.g piping etc if i need to block off any pipes what do i need?
Also by doing this do i need to bypass the n249 aswell?
Heres the catch can i was looking at http://www.ebay.co.uk/itm/Black-Alloy-Oil-Catch-Tank-Can-10mm-15mm-Inlets-VW-Polo-Golf-Bora-Jetta-GTi/130930567556?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D8654111020240125972%26pid%3D100011%26prg%3D1005%26rk%3D1%26sd%3D360442541907%26
Any help would be appreciated, cheers
Offline GTi_James
Re: Catch can and pcv system
« Reply #1 on: 26 June 2013, 20:02 »
maintenance section buddy, its all there
Offline WadGTI
  • Golf GTI'er
« Reply #2 on: 26 June 2013, 20:22 »
I have done a fair bit of reading up on the systems and removal. It aint the easiest thing to follow in my view.
To the OP, do a good bit of google searching on it, as there is a number of different forums with different guides, with conflicting info on some. I found a few helpful topics specifically on the seat forums. Not sure if your engine was put into a seat?
I will try and post some links when I have time.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 26 June 2013, 21:07 »
The trouble with cheap catch cans is the lack of condensing material inside them
Offline Jayz
« Reply #4 on: 26 June 2013, 21:44 »
I agree
Offline Jayz
« Reply #5 on: 26 June 2013, 21:47 »
Take it these are the best ones to get?
http://www.ebay.co.uk/itm/300923892823?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
« Last Edit: 28 June 2013, 05:51 by Jayz »
Offline baxxy
« Reply #6 on: 24 August 2013, 11:50 »
Just fitted one of these fitted perfect doesnt look an eye sore under the bonnet maybe a bit expensive but worth the extra £££  :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 24 August 2013, 11:58 »
yep got one of those too
Offline ReDBull
« Reply #8 on: 24 August 2013, 15:05 »
This is a very good thread
http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/118021-guide-how-fit-catch-can-simplify-pcv-system.html
Lots of useful info on ASN! :smiley:
I'm in the process of doing this my self because this!
And what I'm replacing it with.
« Last Edit: 24 August 2013, 15:07 by ReDBull »
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
