Golf mk4
Wazzzer
does anyone elses 20vt do this...
Topic: does anyone elses 20vt do this... (Read 1016 times)
Rod1-gti
26 June 2013, 17:47 »
On odd occasions, when starting from cold, she revs to about 1250rpm (choke) but after a few seconds it hisses, almost like a pressure valve has released. just curious as to what it is as it doesn't do it all the time.
WadGTI
Here all the time
Golf GTI'er
Re: does anyone elses 20vt do this...
26 June 2013, 20:24 »
Get the idle control valve and give it a clean...see if it clears up.
Mines does it now and again on cold start but usually drops quickly. I need to do my valve.
Rod1-gti
26 June 2013, 21:26 »
Cheers boss, ill give it a try
Jin_C
GTI forum regular
26 June 2013, 22:04 »
I dont think there is an idle control valve on the 1.8t's only throttle body.
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
52GTIPETE
27 June 2013, 13:15 »
It will be the PCV for sure. Mine did this with a split in the small pipe from the PCV to the inlet manifold.
Rod1-gti
28 June 2013, 12:06 »
PCV = Pressure control valve I assume?
Golf mk4
Wazzzer
