Author Topic: MOT Fail: Exhaust engine idle speed too high...  (Read 841 times)
Offline GunnerCP
« on: 26 June 2013, 12:04 »
Hi,
So the not so trusty old golf (agu) failed its MOT on the above. They thought it could be a split pipe but were unsure.
The car pulls and runs fine, I cleaned the throttle body out and followed the realignment process listed with vcds. The two typical poor hoses from the inket mani to the fpr and recirc valve have been replaced with silicone.
The test/results were 890 when the range is 650-870
Can I alter this in vcds at all? Anything i can log to aid diagnostics? Any other suggestions to get it through?
Thanks
Offline Granta Gti
Re: MOT Fail: Exhaust engine idle speed too high...
« Reply #1 on: 26 June 2013, 13:42 »
Have you got a splitter or recirc valve and any codes for your lambda sensor.
Offline GunnerCP
« Reply #2 on: 26 June 2013, 21:58 »
It's got a crappy baileys valve that came on the car, do you think that could be the cause? I've got a catch can to fit too but just running out of time but I guess that'll eliminate a valve and some oem/13 year old hoses!
No error codes at all, mpg also seems fine to me so believe the lambda is ok.
Offline Granta Gti
« Reply #3 on: 26 June 2013, 22:09 »
Is it a fully recirculating valve? If it is not swap it for the standard one or a fully recirc for the mot. They do make cars run rich and it is close to the limit so give that a try
Offline GunnerCP
« Reply #4 on: 26 June 2013, 22:23 »
To be honest I've got no idea, I don't know what model it is or what not, it's not overly loud though.
I think I'll pick up a forge 008, I planned to but not this month, tax, mot....  :sick:
Just want it sorted though, I don't have an oem valve so nothing to replace it with.
