Author Topic: knock from front wheel, constant  (Read 1758 times)
Offline kingaz
« on: 26 June 2013, 06:17 »
Got a constant knockong coming from my front wheel, worse when u go round a roundabout though..
Any ideas?
Az
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: knock from front wheel, constant
« Reply #1 on: 26 June 2013, 07:42 »
Wheel bearing?
Offline GTi_James
« Reply #2 on: 26 June 2013, 08:42 »
Offline xtetx
« Reply #3 on: 26 June 2013, 09:09 »
CV joint? ive had to replace both drive shafts this week. Its a ball ache. what ride height you at? standard or lowered?
in my experience a wheel bearing is usually a grinding noise!
Also check your wishbones if a bush has collapsed it could be that also. Ive also just had to replace my wishbones as I thought it was them!
« Last Edit: 26 June 2013, 09:11 by xtetx »
Offline kingaz
« Reply #4 on: 26 June 2013, 15:38 »
Need a good look underneath then.. its lowered on coilovers btw mate
Offline xtetx
« Reply #5 on: 26 June 2013, 17:42 »
How long has it been lowered on coilovers for and when was the last time you changed your cv joints in your drive shafts?
Offline kingaz
« Reply #6 on: 26 June 2013, 17:58 »
A long time and never lol
Offline xtetx
« Reply #7 on: 26 June 2013, 18:01 »
Bet your cv joints are dead then
Offline WadGTI
  • Golf GTI'er
« Reply #8 on: 26 June 2013, 20:26 »
Can't be good on the driveshafts  :sad:
« Reply #9 on: 26 June 2013, 20:48 »
I would check your cv joints.
