Author Topic: Ignition timing  (Read 2253 times)
Offline Sgt_Lemon
  • 8v owners club
Ignition timing
« on: 25 June 2013, 19:35 »
I recently fitted a ported and polished head with fast road cam. I have set the timing to the factory spec 6 degree mark however the idle is rough and jumpy. Would adjusting the timing to the smoothest idle off ear be best or are these just symptoms of the cam, head etc.
Offline Ben Lessani
Re: Ignition timing
« Reply #1 on: 26 June 2013, 08:52 »
Is your static timing actually correct?
Offline oakgreener
Re: Ignition timing
« Reply #2 on: 26 June 2013, 11:51 »
You haven't disturbed the wiring to the throttle body switches?
Offline Sgt_Lemon
  • 8v owners club
Re: Ignition timing
« Reply #3 on: 26 June 2013, 12:41 »
I used a timing light with an advance adjuster and set it up as described on the "how to tune your 8v" thread. I also occasionally get a symptom of an air leak with a hunting idle occasionally but not always.
Offline gazareth
Re: Ignition timing
« Reply #4 on: 26 June 2013, 19:58 »
hi what camshaft you got? you will definatly get a rough idle if you put to wild a cam in. if it was mine I would set timing to standard and go out for a long run with it. as long as you got no pinking and it pulls well and doesn't guzzle the gas should be sound. ideally you should get it on dyno though.
Offline weazgti
Re: Ignition timing
« Reply #5 on: 26 June 2013, 20:43 »
What's with setting up the gun with advance? I didn't think that was needed for 8v s.
I used to use one from about 1952 with just a stobe and it did the job.
Offline gazareth
Re: Ignition timing
« Reply #6 on: 26 June 2013, 21:54 »
if your timing it of a tdc mark you need to adjust gun to 6 degrees advance but if your timing it of a mark on flywheel that's 6 degrees of tdc then you need to set gun to zero degrees.
Offline weazgti
Re: Ignition timing
« Reply #7 on: 26 June 2013, 22:25 »
I see. I didn't think bout the op setting gun to zero. I thought advance had been dialled in but on the tdc mark.
Offline gazareth
Re: Ignition timing
« Reply #8 on: 26 June 2013, 22:36 »
yeah same effect either way. as long as you don't do both or you end up with a can of marbles under your bonnet :shocked:
Offline Sgt_Lemon
  • 8v owners club
Re: Ignition timing
« Reply #9 on: 27 June 2013, 08:45 »
I thought a rough idle may be because of the high lift cam, the fuel economy has shot down 10 mpg. Not sure if its because I enjoy a heavy right foot even more now,  will see what I get with a long motorway drive today.
