Author Topic: Help with a non starting polo!  (Read 3129 times)
Offline Khare
  • The bear that khares
« on: 25 June 2013, 16:16 »
Tricky one.
1.4 1997 polo
Battery is good, reading 12.7v with the car off. When cranking it over from cold, it doesn't want to start, it kind of does, but it doesn't fire up. When bump starting it it starts up just fine. Once it's going and it's warmed up, it'll start off the key just fine. Checked spark and seems strong from the coil, vagcom didn't throw up any codes. Any ideas? Plugs, leads and cap are a few months old only.
Offline G601950cc
Re: Help with a non starting polo!
« Reply #1 on: 26 June 2013, 00:05 »
Is your starter motor turning at a good speed
Offline golf-sib
  • Турботазик
« Reply #2 on: 26 June 2013, 08:56 »
Throttle body it's semi electric on the 6n the cause of many issues. Try cleaning it
I've taken it you checked the dizzy cap and rotor arm?
Last thing is the warm feed on drivers side that uses a bimetallic valve to feed warm air from exhaust manifolds at the front of the car to speed warming up
« Last Edit: 26 June 2013, 08:58 by golf-sib »
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Khare
« Reply #3 on: 26 June 2013, 21:39 »
Yup. Turns over just fine.
Will try cleaning the TB. Yes I've checked leads, cap, rotor and spark from coil. I replaced the plugs, leads, rotor arm and cap about 2 months ago, and it all worked just fine then.
Warm air feed wouldn't cause it not to start. It's not exactly -20 outside!
Offline G601950cc
« Reply #4 on: 27 June 2013, 11:01 »
Does your engine have throttle position switches on throttle body. Have you checked you have good spark at coil end.
Offline Khare
« Reply #5 on: 27 June 2013, 14:17 »
Spark is good at coil end yeah. Not checked for any throttle position switches. I'll have another look.
Offline Khare
« Reply #6 on: 28 June 2013, 12:56 »
Update. Cleaned out the throttle body, it was very clogged. Started first time but when opening the throttle it'd bog down and try to die. Anyway it eventually cleared as it warmed up and off I went. 5 minutes later my mate called me saying it wouldn't start again. Back I went and I cleaned out the earths and tried to start it up. Eventually it did get going without any bogging down and it drove fine. I fear it'll be a problem to start again at some point. Any suggestions? I reckon throttle body is faulty, maybe the tps. He's going to run some redex through see if that helps, could also be a partially clogged fuel line.
Offline golf-sib
  • Турботазик
« Reply #7 on: 28 June 2013, 13:28 »
Them throttle are always a pain every 6n I've nearly seen and owned had issues and a new TB is around 120.
e other awful thing I found even with no gasket issues is the breather would always mayo up and run down to the throttle.
1.8T AGU..
R135
  24
Offline 52GTIPETE
« Reply #8 on: 29 June 2013, 13:07 »
Very common problem on the polo is the temp sensor. My other half had the same problem on hers. Trouble starting from cold and hot.
Offline Khare
« Reply #9 on: 06 July 2013, 21:51 »
Throttle body changed and still has the same issue. Temp sensor didn't show up on vagcom, I would have thought it would show up if it was faulty. Has anyone got any other suggestions?
