Author Topic: Rear tyres rubbing on bumps  (Read 2724 times)
Offline spudboy6
  • Just like a golf ......
« on: 25 June 2013, 15:24 »
So I fitted some new wheels
7j et20 15".  And they rubbed like mad.  Had the front lips rolled the rears rolled and flared all good , but now on hard bumps the tyres hitting up inside the actual wing now on the back , so I need to find some sort of way to stiffen the rear up before I kill the edge of my tyre. Wheels clearing the actual arch lip , just catching up in the 3/4 pannel now :(
Its lowered 60/40 on ta technics shock and springs.  So do I need a better quality stiffer spring on the back or better shocks ?
Offline FlashRedThree
  • MK III Flash Red 1.4 SE + MK V DBP 2.0T GTI
Re: Rear tyres rubbing on bumps
« Reply #1 on: 25 June 2013, 15:28 »
Different tyres probably needed. What you running now?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #2 on: 25 June 2013, 15:55 »
Hazarding a guess I'm gonna say your tyres are too big or the shocks are knackered as 15" wheels and only a 60mm drop should not rub,  let alone with rolled arches all round.
Offline Foreveryoungaus16v
« Reply #3 on: 25 June 2013, 16:09 »
I like the white on blue
163 BHP (TSR POWER RUN)
Offline tweed
« Reply #4 on: 25 June 2013, 18:07 »
Smaller tyres for sure! And a set of jom coilovers will keep it stiff.
My 9j et20 dont rub  :wink: and thats with 195.45.16
Gavv8
« Reply #5 on: 25 June 2013, 18:09 »
Your not running spacers are you?
Offline spudboy6
« Reply #6 on: 25 June 2013, 19:46 »
No spacers , 195/50/15
It rubs the very outside and sidewall can still carry 3 people In The car no problem but bloody bumps.  It clears the arch and the wheel jut hits the top and I have bump stops on the shocks aswell
I've noticed there isn't much clearance straight up inside as its double skin
The shocks don't look like they've leaked only 10months old at most , but the rear springs are like cheese so soft !
May try a smaller rear tyre ?
Offline tweed
« Reply #7 on: 26 June 2013, 10:40 »
No point your problem is your springs
« Reply #8 on: 26 June 2013, 10:49 »
Switch to coilovers which would be stiffer plus et20 is always going to be tight for clearance.
« Reply #9 on: 26 June 2013, 11:38 »
Yup, those tyres should be fine really. It's got to a shock / spring issue.
