Author Topic: High Beam Assist - Hardware or Software?  (Read 11551 times)
Offline Mr Savage
« on: 25 June 2013, 14:15 »
I was just wondering about the High Beam Assist and Park Assist. I wonder if they add hardware to give these the added functions?
I know the auto-lock feature could simply be turned on through VAG com on the Mk5's, along with the cornering fog lights. They were generally just disabled at factory even though the technology was there.
It would be pretty great if we could enable High Beam Assist for free through VAG com :D Park Assist also possibly but I'm guessing this will be less likely. Both use the sensors already on the car i'd imagine? I'd think the high beam assist simply detects other cars headlights through the dusk sensor, but I could be wrong, if that's the case then surely it just needs enabling through VAG com?
« Last Edit: 25 June 2013, 14:20 by Mr Savage »
Current - MK7 Golf GTI - Tornado Red, 5 Door, DSG, Performance Pack, Dynamic Chasis Control, Panoramic Sunroof, Discover Navigation, Dynaudio.
On Order - MK7 Golf R - Pearlescent Black, 3 Door, DSG, Vienna Leather, Discover Nav Pro, Rear View Camera, High Beam Assist, Keyless Entry, Dynaudio (Tech Pack)
All gone.
Now;
MK7 Golf R - Lapiz Blue, 5 Door, DSG, Carbon Nappa, Discover Nav Pro.
Offline monkeyhanger
Re: High Beam Assist - Hardware or Software?
« Reply #1 on: 25 June 2013, 14:26 »
Quite possibly. XDS on my Scirocco was purely a VCDS activation - hardware already there by way of the ABS system and it's sub-systems.
Offline Bill_the_Bear
  • Yes! Wait a minute... No!
« Reply #2 on: 25 June 2013, 15:14 »
For park assist there is a video here:
http://www.volkswagen.co.uk/technology/parking-and-manoeuvring/park-assist
Describes the following:
Ultrasonic sensors (is this the normal parking sensors?)
An intelligent steering assistant (already existing hardware or separate?)
System steers (seems more like this isn't pre existing...)
To be honest having reviewed this video the most useful park of this would seem to be the detection of the size of the space.  After that it is doing the manoeuvring, but if you are halfway competent you shouldn't have an issue.  Then again, only takes one error to damage those alloys!
For high beam:
How does the car detect headlights?  Isn't there supposed to be a camera in the upper front of the windscreen?  Not sure if we get that on the GTI and if not then it needs new hardware to use this right?
« Reply #3 on: 25 June 2013, 15:28 »
For high beam:
There are additional sensors for park assist - 1 on each side of the bumper close to it's edge with the wing. These detect the space as you slowly drive past it, to determine it's size. If not for the omission of the additional 2 sensors, adding park assist would probably be a software update only (how much extra hardware could they pack in while only charging us an additional £135 for it?).
Unsure about high beam. I would wonder whether the dusk sensor is sensitive enough to pick up headlights coming your way to knock yours down to dipped beam or whether extra sensory equipment is required. Hoping that with Xenons I won't need high beam very often. The high price £500ish would suggest to me that some extra hardware is there somewhere rather than just software activation (although VW could just be ripping us off).
« Last Edit: 25 June 2013, 15:32 by monkeyhanger »
« Reply #4 on: 25 June 2013, 15:35 »
Are these seperate to the ones shown in this image, or are the sensros just forward of the arch only fitted with the park assist options?  Anyone know?
Offline peterdoherty
« Reply #5 on: 25 June 2013, 15:38 »
It appears the extra sensor is missing in this pic therefore I'd say they are part of the park assist
« Last Edit: 25 June 2013, 15:42 by peterdoherty »
MKVII GTD DSG Carbon Grey 5DR, Dynaudio, Keyless Entry, Rear View Camera, Colour MFD, Park Assist, Winter Pack, Climate Screen, Advanced Phone Kit, High Beam Assist
« Reply #6 on: 25 June 2013, 15:40 »
Bung the little [img] tags on your image and it will appear in the post.
Got point though... and damn.  I was hoping those side sensors were standard.
« Reply #7 on: 25 June 2013, 15:42 »
The side ones are the park assist specific  ones - just 4 on the front bumper without park assist, 6 with park assist.
Offline mike.
« Reply #8 on: 25 June 2013, 16:19 »
The retail price for the actual high beam assist headlamp units are £160 dearer than the adaptive only units so I would assume there is some extra hardware in the light itself.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Jimble
  • Moderator
« Reply #9 on: 25 June 2013, 17:07 »
High beam assist uses a camera built into the rear view mirror which is not there unless it's specced from the factory so some hardware would be required.
