Author Topic: what steering wheels fit a 1984 mk2 golf.  (Read 1390 times)
Offline VWchapman17
« on: 25 June 2013, 13:38 »
apart from the obvious original mk2 steering wheel
what other steering wheels fit.. for example
lupo
polo
mk3
seat
Offline gazareth
Re: what steering wheels fit a 1984 mk2 golf.
« Reply #1 on: 26 June 2013, 22:10 »
you can fit a mk3 gti wheel but you need to take the spline spacer with it which are a pig to get off. but the later mk2 appears to have the same set up as the mk3. spline spacer comes of with a decent set of pullers or failing that maybe fit a later column and wheel? not sure if its a straight swap though but worth a look.
Offline VWchapman17
« Reply #2 on: 26 June 2013, 23:45 »
ahh I see
thanks a lot mate, helps a lot!!
