Golf mk4
Wazzzer
Is it possible to fit seat cupra r 225 brake set up
Topic: Is it possible to fit seat cupra r 225 brake set up (Read 859 times)
Mk2_tel
Here all the time
24 June 2013, 21:24 »
The brembo brakes not sure what the disc size is
Also where is the link on here for fitting bigger brakes cheers
jamie16v
Guest
Re: Is it possible to fit seat cupra r 225 brake set up
25 June 2013, 01:24 »
yes, its possible. but probably depends on what size wheel you have fitted.
Wayne
Sir Postalot
26 June 2013, 10:57 »
Disc size is 323mm from memory and you will need a minimum of 17" wheels OR 18" would give you more room.
Mk2_tel
Here all the time
26 June 2013, 18:57 »
Would they just bolt on?
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
26 June 2013, 21:11 »
Yes they will but the wheel may not. The Cupra R wheels have very shallow spokes to accommodate the calipers
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
Golf mk4
Wazzzer
