Author Topic: Annoying Rattle from Underside of Car  (Read 14581 times)
Offline MK6-Fan
« on: 23 June 2013, 14:46 »
For the last few months now I have been hearing a rattling sound coming from the underside of the car. It only seems to be heard when I drive below 30MPH intermitantly.
When I travel above 30MPH it's fine, no noise to be heard but it just seems to be rattling at slower speeds.
I've no idea what this noise is or where it's come from but it's a bit annoying.
The cars a 12 plate Golf Match 1.4 TSI & isn't even a year old if that's any help.
2012 Golf MK6 Match 3dr|1.4 TSI 122PS|Manual|Solid Black|MFSW|RCD510|
Offline RocketRossUK
Re: Annoying Rattle from Underside of Car
« Reply #1 on: 23 June 2013, 14:52 »
think i ve seen this before, its the heat shield around the exhaust, it vibrates / resonates and sounds like a knocking / rattle from under the car.
Try wedge or pull it away slightly and see if that fixes it.
Offline MK6-Fan
« Reply #2 on: 23 June 2013, 15:05 »
Thanks. Glad to see that it appears to be common even though it's a pain in the arse!
I'm not very mechanical minded so don't feel confident doing what you suggested. Is it something that could be covered under warranty do you think?
Could the exhaust bracket be loose? Should I jack the car up to see?
« Reply #3 on: 23 June 2013, 15:13 »
Yeah jack the car up, the heat shield around the exhaust  attached to the car, just make sure that's no lose or wobbly, if it is, just try tac it down.
Offline andyr
« Reply #4 on: 23 June 2013, 16:11 »
If it's not a year old yet then I'd say take it to the dealers. The exhaust itself *may* not be covered, but if the heat shield is ratting - or a weld snapped perhaps - then let them take a looksee first, else they may say "It's been fiddled with so it's not covered under the warranty!"  :shocked:
Mk VI Black Pearl GTD.... No Frills, replaced a Black Pearl PD150 Bora, which in turn replaced a Dragon Green VR6 which followed a Dusty Mauve MK III 8v Gti.
Offline Ginge 35Edition
« Reply #5 on: 23 June 2013, 18:45 »
Straight to the dealers dude! If you break something then you'll be buggered!
Offline mkviken
« Reply #6 on: 23 June 2013, 19:08 »
It might just be a stone trapped somewhere underneath.
Alot of times this happens and sounds horrendous but is nothing to worry about.
Golf GTI 7.5 230 white silver
Offline mwad gti
« Reply #7 on: 23 June 2013, 20:47 »
I had this also on my last car - a 60 plate Golf GT.
The exhaust heat shield was to blame
Candy White 3 dr Manual 2012 GTi. Bought new.
DAB, Dynaudio, Kenwood Head Unit Upgrade, Private Plate,
Full Leather and Heated Seats
18" Shadow Monzas, luxury pack.
Colour coded side skirts and gloss black diffuser.
Jimmymature
« Reply #8 on: 23 June 2013, 21:22 »
I had the same issue as was fixed under warranty. Here is the link to the original thread.
Seems like VW has found a solution to this issue that I found on the internet. It's an easy fix with a small clip that goes on the wastegate rod. I've already ordered mine from my local dealer and they easily found the part on their database.
OEM part number: 06J-145-220-A / 06J145220A
Video: http://www.youtube.com/watch?v=xAkkIEMm3UQ
http://www.golfgtiforum.co.uk/index.php?topic=149969.0
VW have issued guidance on this noise as follows...
Technical product information Transaction No.: 2021062/1
Rattling noises from engine/exhaust system Release date: 10-Jul-2009
Customer statement / workshop findings
Rattling or jarring noise from the engine compartment / exhaust system when accelerating between 2400 and 3000 rpm .
Technical background
Waste gate adjustment rod of the turbo charger rattles when accelerating.
Production change
« Last Edit: 23 June 2013, 21:24 by Jimmymature »
Offline Jimble
« Reply #9 on: 23 June 2013, 21:43 »
I had the wastegate rod clip put on mine but i thought that was just the GTI? Didn't realise it affected other engines! :o
