Author Topic: MK4 gear box  (Read 1360 times)
Offline mar_k
MK4 gear box
« on: 22 June 2013, 19:54 »
Did any Mk4 Gti's come with LSD's?
Reason I ask is I have just picked up a gearbox that appears to have one fitted.
Its from a 2002 1.8 Gti apparently.
When I turn one of the output flanges the other side turns in the same direction.
Either it has an LSD or there is a fault with the box.
jamie16v
Re: MK4 gear box
« Reply #1 on: 22 June 2013, 20:28 »
interesting! only one way to find out... well, two actually but taking it apart would say for sure :smiley:
Offline mar_k
Re: MK4 gear box
« Reply #2 on: 23 June 2013, 16:50 »
Ill make a short video when Im at the lock up in the week.
Offline navmk4gti
Re: MK4 gear box
« Reply #3 on: 23 June 2013, 19:44 »
I thought none of the mk4s had lsd
Offline Chris.
Re: MK4 gear box
« Reply #4 on: 24 June 2013, 01:23 »
none, came with a LSD.
Click For Build Thread
Offline tshirt2k
  • Been there...Done that...
Re: MK4 gear box
« Reply #5 on: 24 June 2013, 08:56 »
The diff in it is probably stiff. I had this on a gearbox I bought.  Jam one of the cups an turn the other.
Mk3 ABF 16VT Megasquirt V3
Offline mar_k
Re: MK4 gear box
« Reply #6 on: 24 June 2013, 20:15 »
Tried that and it don't budge, Both side turns together.
Offline tshirt2k
Re: MK4 gear box
« Reply #7 on: 24 June 2013, 20:23 »
Not with your hands. Put bolts in the cups and use levers.
