Golf mk4
Wazzzer
pedal depressed for bleeding brakes
Topic: pedal depressed for bleeding brakes (Read 1118 times)
vala
21 June 2013, 21:36 »
Can anyone tell me why it is the official VW method for bleeding the brakes involves having the brake pedal depressed throughout the entire process?
jamie16v
Guest
Re: pedal depressed for bleeding brakes
21 June 2013, 23:19 »
according to what I`ve read in the past, and if you`re using a pressurised bleeder, then yes, I believe so.
vala
21 June 2013, 23:40 »
jamie16v - thanks for the reply. I will be using a eeziebleed to do the job but wanted to know why it was that the official method from VW involved depressing the pedal thoughtout the process.
jamie16v
Guest
21 June 2013, 23:43 »
I`m not totally sure, but I think it has something to do with the abs pump.
km
22 June 2013, 01:27 »
bled my system also using eezibleed with pedal untouched. worked fine for me.
vala
22 June 2013, 18:18 »
km - thanks for the reply. I'll be using an eezibleed system as well so that's reassuring to hear.
Golf mk4
Wazzzer
