The garage
Rear beam bush replacement time?
Topic: Rear beam bush replacement time? (Read 1834 times)
mike3112
Just got here
21 June 2013, 15:34 »
hi guys,
ive noticed when i hit a bump or hole with the back left the car goes into a wobble, do you reckon this could be the bush has worn? is there a simple way to test this?
mk 4 golf tdi**
Last Edit: 21 June 2013, 15:57 by mike3112
Screech16v
MK3 20vt AGU
Re: Rear beam bush replacement time?
26 June 2013, 22:25 »
Could be your shocks.
TDIgadge
GTI forum regular
27 June 2013, 09:44 »
More likely the rear shocker. Easy test is to have someone (bigger the better) jumping/bouncing on the tailgate opening. Rear bush will back, bouncing =shock (visual check for leaks also) HTH
The garage
