Author Topic: duel mass replacement to solid flywheel  (Read 3145 times)
Offline sean150
« on: 21 June 2013, 12:31 »
Hello all im thinking of replacing the duel mass to a solid flywheel but Ive heard that the gearbox gets louder not sure about this and will the pedal be harder to push the car is an 02 gti150 diesel its also mapped to about 185bhp will the solid flywheel be better if so what kits work well tnx in advance and sorry for all the questions
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: duel mass replacement to solid flywheel
« Reply #1 on: 21 June 2013, 14:45 »
Dare I say a SMF (single mass flywheel) is almost unbearable. There is a huge difference in diesels with the fly wheels.
Standard uprated replacement clutch - http://www.darksidedevelopments.co.uk/products/sachs-dual-mass-flywheel-and-darkside-clutch-kit-for-vw-02m-6-speed-1-9-tdi.html
Standard replacement clutch kit - http://www.darksidedevelopments.co.uk/products/sachs-1-9-tdi-6-speed-02m-dual-mass-flywheel-and-clutch-kit.html
Some good reading involved with the SILENT SMF kits. Very expensive but the dog bollocks. - http://uk-mkivs.net/forums/p/449891/3139675.aspx
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 21 June 2013, 16:58 »
I replaced my broken DMF with a SMF on my 110AHF mk4 and it was very noticeable. Especially when reversing off the drive the car had big vibrations.
After I fitted a polybush to the dogbone mount it was even more so.
So glad when I sold that car and went back to DMF on the 150PD
Mk4 Golf 150PD
Offline Rhyso
« Reply #3 on: 21 June 2013, 17:35 »
Providing the map is smooth and progressive the standard replacement kit will be fine
Upgrade if you plan on wanting more power
Offline Hoggy
  • Mk4 GT TDI 150.
« Reply #4 on: 25 June 2013, 22:11 »
Personally wouldn't do it..
Even heard of them snapping crankshafts  :sick:
