Author Topic: Wheel spacer, on wheel spacer. Big no no?  (Read 1414 times)
Offline Hoggy
  • Mk4 GT TDI 150.
« on: 20 June 2013, 20:14 »
More out of curiosity than any thing:
Say I have 2 5mm spacers and 2 10mm humcentric spacers, and I was wanting 15mm spaced each side, is it forbidden or just frowned upon to put two sets of spacers per side?
This would just be a temporary solution on a mk4 Golf.
Thanks, Hoggy.
« Last Edit: 20 June 2013, 20:17 by Hoggy »
Offline dom
  • Back in a Mk4
Re: Wheel spacer, on wheel spacer. Big no no?
« Reply #1 on: 20 June 2013, 20:44 »
Not something I would even consider doing to be honest. That said, a similar question was asked on Edition recently and the advice given was that it would be fine but they're all spring chopping numpties :lipsrsealed:
Offline Hoggy
  • Mk4 GT TDI 150.
« Reply #2 on: 20 June 2013, 20:51 »
Cheers dom, it's something I can't make my mind up on, I know it's not ideal, but it would just be temporary :)
Cheers, Hoggy.
Offline james2
  • No scammers please.
« Reply #3 on: 20 June 2013, 21:51 »
You can have 25mm or was it 55mm spacers but you can not have the wheel sticking out of the arch so need wider wheel arches. I was watching chop shop lupos sumo car.  :laugh: lol look at the size of the rear spacers.  :shocked: http://www.youtube.com/watch?v=96AGEugR3-o
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline SI74
« Reply #4 on: 20 June 2013, 21:59 »
I wouldnt do it myself too. Might not be no problem doing it but it would always be in the back of my mind.  The two would never be as strong as one.
Yea but hes asking about putting a 5 on top of a 10.
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #5 on: 21 June 2013, 08:40 »
If you had sufficiently long bolts I think it would probably be ok, OBV not ideal. I certainly wouldn't condone it for a long period of time. Defo pick up the correct size one next time on egay!
Offline Hoggy
  • Mk4 GT TDI 150.
« Reply #6 on: 21 June 2013, 21:56 »
Will be ordering the right size spacers when I get the exact mm measurement right :)
Being on air I want that arch right on the lip ;)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #7 on: 22 June 2013, 00:47 »
Those spacers are ludicrous!
« Reply #8 on: 22 June 2013, 23:51 »
Would not even consider it tbh.
