Author Topic: Very slugish and won't pull past 5000rpm  (Read 2732 times)
Offline Craigwilson
« on: 19 June 2013, 19:37 »
Right my 91 8v gti  has a problem at first when I turned on my ignition my fuel pump relay would either click very rapidly or the fuel pump just wouldn't stop priming and the car wouldn't start on either, after fiddling about it finally started and it drives, it sounds a bit rough on idle and when I put my foot down it just won't go like it should and when I hit 5000rpm it takes aggeesssss to move to 6000. Any ideas ?
Offline dubber36
Re: Very slugish and won't pull past 5000rpm
« Reply #1 on: 20 June 2013, 08:13 »
It could be that 8 of the required amount of valves are missing.
Offline Craigwilson
« Reply #2 on: 20 June 2013, 09:34 »
Touchè
VW BUSH
« Reply #3 on: 20 June 2013, 11:08 »
 :grin:
Offline Craigwilson
« Reply #4 on: 20 June 2013, 11:55 »
Turns out the other 8valves kill my insurance
Offline Foreveryoungaus16v
« Reply #5 on: 20 June 2013, 19:24 »
Not surprised my last Mk2 was slow a sh!t near that range. It is not a fast car.
163 BHP (TSR POWER RUN)
« Reply #6 on: 20 June 2013, 19:26 »
A 16v really comes alive that range
Offline Craigwilson
« Reply #7 on: 20 June 2013, 19:31 »
Well my car has never been this slow its only been the past few days and the idle is also rough now
« Reply #8 on: 20 June 2013, 19:54 »
Tk it to a Vw garage or good mechanic and get a full service etc then. You have to understand that the 8v has good low down torque but after 4000 ish its sluggish
Offline Craigwilson
« Reply #9 on: 20 June 2013, 19:59 »
But it still pulles well all the way to the limiter well mine did anyway and now it struggles past 5 and even getting there past 2-3k it's very slow
