Author Topic: Fitted Lowering Springs but...  (Read 1842 times)
Offline kidhannn
« on: 10 August 2005, 19:40 »
Hi,
I got new shocks and lowering springs fitting on my car (bought the set from eurocar parts).
But, the front seems to be lower than the rear. Any ideas why this is the case?
Thanks
Offline greenie
Re: Fitted Lowering Springs but...
« Reply #1 on: 12 August 2005, 10:45 »
Its normal ...mine is the same even standerd they are slighty lower unless the strutts at the rear are the wrong one !!
Offline tyler
« Reply #2 on: 12 August 2005, 12:14 »
make sure the springs are sat right in the bottom and top off the shocks souldnt be able to twist them if can twist them until there stop
corrado 16v lowered,leather,grill,oz route,m3 lights polished engine,
mk1 golf cabby not alot done but in primer
Offline technics
« Reply #3 on: 12 August 2005, 13:59 »
Yep, mines the same.
I got some BOGE turbo gas shocks and GSF's own lowering springs.
Supposed to lower by 40mm, but personally I couldn't tell the difference, well at the rear anyway, it looks like a dragster.
Im a bit gutted as it was a lot of messing about, and i've seen quite a few Clippers that are really low. :-(
Renault Alpine GTA Turbo
Mk1 Golf Clipper
Offline Tucker
« Reply #4 on: 14 August 2005, 21:16 »
Engine heavier than the petrol tank :wink:
http://i10.photobucket.com/albums/a109/sydney04/mk116vsmallpic.jpg
Sig too large, see forum guidelines - Admin.
Offline BobbyT
« Reply #5 on: 15 August 2005, 23:00 »
mines the same! guess its normal, with coil overs you can lower the rear more! if only i had a spare 600 or so quid!  :angry:
Offline Bronze MK1 Cab
« Reply #6 on: 16 August 2005, 08:32 »
Mine sits lower at the rear  :sad: Got mine from GSF too  :wink:
