Author Topic: Rad Fan  (Read 1402 times)
Offline 92 rocks
Rad Fan
« on: 10 August 2005, 19:29 »
Fellas
The rad fan on my 89 16v has suddenly become the noisiest in the UK, my elderly neighbours love it  :grin:
I have a spare in my garage from an 89 8v, will it fit and if so how big a job plz?
Ta
Stuck in the 80s? Nope its a 92!
Re: Rad Fan
« Reply #1 on: 10 August 2005, 22:46 »
Straight swap!  4 bolts hold the rad shroud on, and 3 bolts hold the fan to the shroud.  Remove all the bolts, swap fans, do em all up again  :grin:
Only thing you have to watch out for is if both fans are the same type, some dubs came with only a single speed fan and others had a 2 speed fan. Way you tell is to look at the fan plug wires, if there are 3 its a 2 speed jobber, if only 2 its a single speed.
Offline 92 rocks
Re: Rad Fan
« Reply #2 on: 11 August 2005, 22:00 »
cheers rub, bloody typical different fans glad i checked! oh well neighbours should be pleased to listen to my fan gives them something else to moan at :grin:
Re: Rad Fan
« Reply #3 on: 12 August 2005, 09:41 »
Spray a bit of WD40 into it, might quiet it down.  Unless you enjoy annoying your neighbours  :grin:
Offline 92 rocks
Re: Rad Fan
« Reply #4 on: 12 August 2005, 22:31 »
Will it take WD then? Didnt know whether it was a sealed bearing? :undecided:
Re: Rad Fan
« Reply #5 on: 13 August 2005, 08:04 »
Now that I don't know, but worth a try :)
