Author Topic: Climate Control - Cold  (Read 5019 times)
Offline Ady TDI
« on: 18 June 2013, 09:18 »
Hi all,
I have a problem with my car heater, if the car is set to HI on the climate it blows out hot air, any other setting 27 degrees etc, I get cold air
Anyone know what this could be ? Also anyone in Heathrow area with Vag Com ?
Thanks
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Climate Control - Cold
« Reply #1 on: 19 June 2013, 22:04 »
Thermostat?
Get it scanned, check out the diagnostics section for locations, that way you should get a good first picture of what is wrong, if anything.
Offline Ady TDI
« Reply #2 on: 21 June 2013, 11:34 »
Thanks for the reply,
I had it scanned this morning and was told that its like a gate thats stuck closed, but its a big job as its behind the dash ?
Offline scarr89
« Reply #3 on: 21 June 2013, 14:39 »
Ahhh, well at least you know the issue. I know that the heating matrix and all the gubbins for the climate control is quite complex. Perhaps get a quote from a garage...
Offline Ady TDI
« Reply #4 on: 24 June 2013, 19:59 »
Scanned it with vag com (ebay version) fault says Anti Flow Flap Positioning Motor (71) 37-00 Faulty
So is this a hard / expensive job ? Is the motor behind the glove box ?
Thanks
Offline kr1s77
« Reply #5 on: 24 June 2013, 20:11 »
clear the fault and then with vagcom, i think you go in to climate control module, basic settings, up to 01 and let it run, youll hear the flaps open/close and when the numbers stop its done. this should reset the flaps. hope this helps.
ASV 1.9 TDI 110
Offline Ady TDI
« Reply #6 on: 24 June 2013, 20:25 »
Just tried this but when I try to go into basic settings it says only registered activated users can use this
Offline scarr89
« Reply #7 on: 24 June 2013, 20:27 »
Yea...the basic lite version only lets you scan it. Not play around with any of the data inputs. Time to find some one local  :smiley:
Offline Ady TDI
« Reply #8 on: 10 July 2013, 14:39 »
Will have to find someone with the full vag com I think, I looked behind the climate unit and the motor does turn when I adjust the temp all tho very slowly, will spraying with wd 40 clean it ?
Offline scarr89
« Reply #9 on: 10 July 2013, 19:29 »
Yea give it a good spray and then a little scrub if needs be. WD cleans and protects, to quote the can I believe!  :grin:
