Author Topic: Just bought a forge 008 FMDV008 Recirculation Valve  (Read 7881 times)
Offline lighters
Re: Just bought a forge 008 FMDV008 Recirculation Valve
« Reply #30 on: 23 June 2013, 19:27 »
Ye I already have a forge 008 that I got for £90 with 3 shims and 2 springs with only 1 weeks use :D
I havent got any with the engine cover off, do you need it? Just had a full service, these are old pics - I know nothing about  cars
Offline dom
  • Back in a Mk4
« Reply #31 on: 23 June 2013, 19:28 »
Completely missed the whole topic of this thread was that you'd bought a 008 :laugh:
Only asked for a pic to see where those blue hoses go to, hopefully down to the fpr :wink:
Offline lighters
« Reply #32 on: 23 June 2013, 19:36 »
Dont have any but will be replacing that valve with the forge one so from what I can understand the hoses should be fine?
jamie16v
« Reply #33 on: 23 June 2013, 19:39 »
youre right, they are not standard pipes, I would still replace them though, it looks a little untidy.
Offline lighters
« Reply #34 on: 24 June 2013, 22:28 »
Well i fitted the dump valve, initial impressions are massive disappointment. It's actually louder than the one I had on, sort of lower volume louder if you know what I mean.
It made absolutely zero difference to throttle response/less turbo lag, expected it to be atleast a little faster. :'( just a different noise
« Last Edit: 24 June 2013, 22:32 by lighters »
Offline Rhyso
« Reply #35 on: 24 June 2013, 22:34 »
What colour springs did it come with??
And what did you fit?
Offline lighters
« Reply #36 on: 24 June 2013, 22:37 »
Yellow spring 2 shims it was prebuilt and also blue spring thats not in use the forge 008
Offline Rhyso
« Reply #37 on: 24 June 2013, 22:50 »
You tried it without the shims? Was it prebuilt with a remap in mind?
Offline lighters
« Reply #38 on: 24 June 2013, 22:52 »
Car has been remapped and I bought it on ebay with about 200miles use, it was already pre-assembled. Nope, surely it needs the shims (I havent a clue but they are included so can only assume)
jamie16v
« Reply #39 on: 24 June 2013, 22:59 »
take the shims aout and stick with the yellow spring.
a forge DV doesn't mean your car will go faster, it just means that its a strong reliable dv!.
