Author Topic: Just bought a forge 008 FMDV008 Recirculation Valve  (Read 7877 times)
Offline lighters
Re: Just bought a forge 008 FMDV008 Recirculation Valve
« Reply #20 on: 20 June 2013, 20:06 »
Still not found any info on belt tensioner and engine mount bolts? what do they do exactly and do I need them replaced?
Was also told to replace  Aux Drive Belt - is this needed / required?
Need to buy these tomorrow so quick replies with solid info would be appreciated, tah
Offline dom
  • Back in a Mk4
« Reply #21 on: 20 June 2013, 20:45 »
Make sure you buy a full cambelt kit, this will include the tensioners. As for the engine mount bolts, I wouldn't bother personally.
Offline lighters
« Reply #22 on: 20 June 2013, 20:53 »
Confirmed I have the full cambelt kit, tah mate
Offline lighters
« Reply #23 on: 23 June 2013, 18:39 »
The dump valve is ready to be fitted, has all springs and shimsetc. do I need any uprated hoses or pipes?
jamie16v
« Reply #24 on: 23 June 2013, 18:42 »
if none of your pipes have been replaced, buy some 3mm silicone vac hose because the old stuff will be perished and will just crumble when you take it off! replace the pipe to the FPR while youre at it.
Offline lighters
« Reply #25 on: 23 June 2013, 18:51 »
Dont think anythings been replaced, pipes seem fine, what exactly am i searching for?
Offline dom
  • Back in a Mk4
« Reply #26 on: 23 June 2013, 19:02 »
As Jamie said, 3mm ID silicone hose is what you want.
jamie16v
Offline dom
  • Back in a Mk4
« Reply #29 on: 23 June 2013, 19:13 »
Get some more pics with the engine cover off, I'd ditch that dump valve though!!
