Author Topic: ECU shorted out,8v p reg,car wont start  (Read 1696 times)
Offline gasketface
« on: 17 June 2013, 21:33 »
Hi all.If anyone ahs any ideas please post.
Just had a mate phone with a prob.He noticed recently that ecu was'nt bolted down but left it.Earlier he hit pot hole and whole lot jumped out.
He thinks that somehow he has shorted the metal frame that is around ecu (do'nt know how as i am miles away) but car wo'nt start now.
Any ideas,could he somehow have blown a relay ? or ecu nacked ?.
Thanks.
Re: ECU shorted out,8v p reg,car wont start
« Reply #1 on: 17 June 2013, 21:53 »
As a guess I suspect you have fried the ECU
Offline gasketface
« Reply #2 on: 17 June 2013, 21:58 »
He just rang and has had ecu apart.tells me that some solder had burned out so i guess we are on the same lines.
Gutted that i just sold the complete set up so i cant help much  :cry:
Offline tweed
« Reply #3 on: 17 June 2013, 21:59 »
Everything connected?
Also have fuses in case of such things happen. I guess fuse blown or damaged ecu relay.
But would defo check that everything is intact first. Could of pulled wires out of plug.
Offline tweed
« Reply #4 on: 17 June 2013, 22:31 »
Ha bit late
Offline boneybradley
  • Back in a Mk3...
« Reply #5 on: 18 June 2013, 09:00 »
just remember if he changes the ecu to get the keys and immobiliser ring thing that match it (or he will need to de-code the immob)
Offline NERF 69
« Reply #6 on: 18 June 2013, 20:58 »
I have an ecu and a ring reader but unfortunately no key get back to me if ur interested. I thought i had the same problem but it turned out to be the crank sensor
Sell my Vw??? I'd rather stick wasps up my arse
