Author Topic: Spring Tension boost?  (Read 755 times)
Offline swanson07
« on: 17 June 2013, 07:40 »
Hi,
I currently have under fueling issue and want to set my boost down to HOPEFULLY get my car running better.
I want to connect a hose from the intake manifold to turbo actuator? removing the boost control in the ecu?
Can some one provide a diagram and more information. I am set on doing this as Im refusing to spend heaps more money as I have a student loan and car loan.
PS: I live in NZ so remap ect is not an option and bigger injectors and fuel pump isnt on the cards YET!
Kind Ragards
David the kiwi
Offline Dalo Harkin
Re: Spring Tension boost?
« Reply #1 on: 17 June 2013, 12:00 »
You'll want a MBC (Manual Boost Controller) easiest way to do what you are talking of
Offline paultownsend
« Reply #2 on: 17 June 2013, 13:04 »
Just unplug the electrical connector? It will then run actuator pressure
