Author Topic: few electrical issues  (Read 2239 times)
Offline t-dub1902
« on: 16 June 2013, 19:30 »
So yep i have a few electrical issues
Main one bejng my passenger electric window doesent work any ideas??
Drivers front indicator doesent work try new bulb would this be the bulb holder?
Also passenger door speaker has no sound
Any idea too all of the above would be appreicated
Cheers lads! :)
Offline SimonG
Re: few electrical issues
« Reply #1 on: 16 June 2013, 22:07 »
For the door related issues, could be broken wires between the door and shell, pull back the rubber bellows and see if you can see anything.
For everything I would check connections and wiring just about everywhere and clean if necessary. A volt meter would be useful for the job.
  Mk3 Anniversary GTI 16V, Mk2 GTI
Offline t-dub1902
« Reply #2 on: 16 June 2013, 22:17 »
Ive had the door card off and all seems ok its strange
Might try new indicator bulb holders maybe???
Offline Craigwilson
« Reply #3 on: 16 June 2013, 23:43 »
About the indicator problem I had a problem with all the earths under the battery and half my lights didnt work, I'd try haveing a look
Offline X4MGS
  • VAG Parts SNOB!!!
For More Info Click To See;
Offline Steve_B
« Reply #5 on: 17 June 2013, 15:40 »
Have you tried swapping the window switches over?
Offline weazgti
« Reply #6 on: 17 June 2013, 16:05 »
Also check for power at the motor for the window. They re prone to seizing or the mech itself getting jammed at the top
Offline Sgt_Lemon
  • 8v owners club
« Reply #7 on: 17 June 2013, 20:35 »
I have fixed both my window switches. The problem was with the terminals switch end. Took the switch apart, took a small file (actually used a nail file) to the contacts. Get them shiny again then lube. Should work good as new
Offline t-dub1902
« Reply #8 on: 17 June 2013, 22:44 »
How do the window switches come out?? Cheers
Offline Steve_B
« Reply #9 on: 18 June 2013, 10:49 »
They should come out with some gentle persuasion. If not, unscrew the centre console and then you'll be able to get to the back of it.
