Author Topic: abs control unit  (Read 1463 times)
Offline nhop10
  • Mk3 GTi
abs control unit
« on: 14 June 2013, 23:18 »
anyone know if the vr6 and my 8v agg abs ecu's are the same? i have the later gti so think it shas the bigger brakes and maybe the same unit? cheers
Mk1 Golf 1.1, 6n Polo 16v, and now an 8v mk3 GTi
Offline swainy
Re: abs control unit
« Reply #1 on: 14 June 2013, 23:23 »
Do you need a new abs ecu?
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #2 on: 16 June 2013, 02:27 »
Ideally could you find the part number of your unit as you need pump/ecu with the same part numbers if needed i have to used units in working order mines an 8v agg also  :wink:
2000 Mkiv GTi 1.8T AGU
Offline nhop10
  • Mk3 GTi
« Reply #3 on: 16 June 2013, 22:14 »
yh ive looked at the unit but the part number must be underneath it so cant see it without taking it off first. but yes i do need a new unit. how much are either of you willing to sell posted to rg9?
  • "1.8T AGU"
« Reply #4 on: 17 June 2013, 22:03 »
the part numbers will be on the black casing of the pump my unit is 1H2 614 117B ecu 3A0 907 379 if yours are the same numbers then your in luck,feel free to pm me and we can sort someting :afro:
