Author Topic: High Biting Point on Clutch  (Read 3714 times)
Offline Hongkongphooey
« on: 14 June 2013, 20:22 »
I'm guessing this is a sign of the clutch wearing out? If so has anyone had to replace a clutch on an 8v GTi and how much is that likely to cost (supply and kit) to get a VDub specialist do this?
It certainly ain't critical but I really don't like the feel of it right now.
Ta
Offline mad4vws
Re: High Biting Point on Clutch
« Reply #1 on: 14 June 2013, 20:47 »
supply & fitted from around £100 to £200 ,clutch kit itself around £80 best to go for luk or sacks better brands mate..
  :cool: :wink: :smiley:
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline Adezmk3
« Reply #2 on: 27 June 2013, 19:17 »
your clutch cable needs resetting
Offline Foreveryoungaus16v
« Reply #3 on: 27 June 2013, 19:27 »
Sachs
163 BHP (TSR POWER RUN)
VW BUSH
« Reply #4 on: 27 June 2013, 20:08 »
Make sure you get the seals done while its off.
About 110 all in for the kit and 150 fitting round here.
Don't forget it will most likely knock your tracking out.
What's your linkage like?
Offline gazareth
« Reply #5 on: 27 June 2013, 20:54 »
hi what do you mean knock your tracking out?
VW BUSH
« Reply #6 on: 27 June 2013, 22:17 »
You have to take the bottom joint apart to get the shaft out. It doesn't always go back exactly in the right place.
Offline gazareth
« Reply #7 on: 27 June 2013, 22:29 »
but you can take out balljoint pinch bolt and lever wishbone down and pull out hub.that way you don't disturb any track settings. I find if you take of gearbox mount then undo cv joint nut you can pull the shaft into engine bay slightly then pull down and out below front bumper. works on mk2 anyway.
VW BUSH
« Reply #8 on: 28 June 2013, 13:03 »
Thats how I do it normally, sometimes it goes back spot on other times it can be a little out.
My old man has tracking equipment so its no bother to me :cool:
A lot of garages pop the bottom joint and rack, ive even seen them take the whole strut out :shocked:
Offline gazareth
« Reply #9 on: 28 June 2013, 18:03 »
