Golf mk3
hardmonkeys
Is it possible to change rear spring/shocks one at a time without axle stands?
Topic: Is it possible to change rear spring/shocks one at a time without axle stands? (Read 1864 times)
b_boy02
14 June 2013, 19:32 »
Basically as the title suggests I think I will need to do this one side at a time. I know the normal way is to jack up the rear then on axle stands drop the axle to give you room to work.
If I jack up one corner at a time nice and high will I be able to push the axle down enough to get the spring/shock assembly out?
Many thanks.
Gavv8
Guest
Re: Is it possible to change rear spring/shocks one at a time without axle stands?
14 June 2013, 19:37 »
I jack the car up with a trolley jack then put the standard jack in between the subframe and body to force them apart.
madmanmart
14 June 2013, 21:55 »
Buy another jack?
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
DCmk3
Here all the time
14 June 2013, 22:48 »
That's what I had to do to lower my golf, I didn't have stands at my place so we put the jack under the axle section which crosses under the car so the axle can still pivot on the jack..
Didn't have any issues with it, although it's not exactly safe either. Not to mention you need to put force down on the axle to get the shock out..
Last Edit: 14 June 2013, 22:50 by DCmk3
2014 Mk7 GTI - Littco L500
b_boy02
15 June 2013, 08:39 »
Sounds pretty dodgy pivoting the axel on one jack, might try Gav's method though. Where did you place the trolly jack to get enough height? I normally jack under the axel as the sills like to fold but obviously that is not an option in this case!
leigh_harty
Audi AGU
15 June 2013, 10:07 »
Why not just buy axel stands? they are cheap enough! Even a halfords 2tonne trolley jack isnt expensive i think i paid £24 for mine and you'll always need a 2nd
Dont lose your dinosaur!
tweed
Forum addict
Reply #6 on:
15 June 2013, 10:21 »
You not got a pile of bricks? Any wood to put on top of bricks? Old tyres?
Im sorry but even I can see this is a accident waiting to happen. Might not get hurt but the car might fall of the jack.
I would ask friends or neighbour first.
Untitled
by
tweedub
, on Flickr
b_boy02
Reply #7 on:
15 June 2013, 10:46 »
Yeah I probably have a bunch of breeze blocks somewhere. Where would you suggest I it supported it on them?
leigh_harty
Audi AGU
Reply #8 on:
15 June 2013, 10:51 »
Chuck 2 under the sump and some on the frame rails where you see the brake and fuel line.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_898889_langId_-1_categoryId_255207
£20 and youll always need a set!
Gavv8
Guest
Reply #9 on:
15 June 2013, 11:42 »
I always jack under the rear subframe mounts or under the front engine mount.
Golf mk3
hardmonkeys
