Author Topic: Engine mount lining up problem after starter motor replaced...  (Read 1458 times)
Offline Third Rail
I've got to that dreaded stage with the front engine mount bolt not going through after replacing the starter.
I've jacked the engine up, i had it jacked while i undid the bolt too, but the holes  are about 6mm away from lining up.
Is there any method to use to get them back? There isn't any room to grab things to shake it or i can't seem to use a screwdriver to lever anything (probably not wise anyway!).
Any help would be much appreciated!
Offline danmusic24
Can't understand why you can't sort it? Maybe stick a long screwdriver through to line it up fella
Offline CJA321
You just have to fiddle about with it. Its a pain to line up sometimes
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Keep everything slack until all bolts are in on a few threads then tighten it all up.
Offline Third Rail
Thanks for the responses here. Yes, definitely keeping things slack helped a great deal, but the trick that nailed it was to loosen off the 10MM allen bolt on the sub frame...made it pop right into place!
